And mostly street driven trucks....Which bore ram did you go with? The GM truck kit that PSC sells comes with the 1.75x8 ram. They also sell a 1.5x8 ram. Would the loss in response with the with the 1.75 ram be worth the gain in power over the 1.5 part? Is there a noticeable difference in street manners between the two? If there's a durability advantage with the 1.75 ram, that's what I want above all. If the smaller rod diameter of the 1.5 ram presents a bending or flexing issue, then that's out. I don't want to deal with leaks or bent rams for the few times my truck will actually see 'trail' time.
This would be going on a fully matched PSC system- box, pump, reservoir and fluid cooler.
I got mine about 2-2.5 years ago, maybe they changed them up at some point.
