1-tonmudder
I am wanting opinion's/insight on a truggy project I am wanting to build.Basically I am going to use spare parts that were left over or gotten for cheap.As of now I have the following parts for it.
454 engine
350 engine
465/205 with 32 spline front
2 sets of Dana 60 5:86 gears
425 Impco propane set up
Most of a hyd clutch set-up
30 spline FF 60 rear
So heres what I your opinion(s) on.
#1 Will it be nose heavy with the 454,no rear sheetmetal and only a cage?
#2 Use the 350 instead of the 454?
#3 I am wanting to run full hydro steering but will a stock ported box and modified pump support this or do I need to be looking out for a charlyn valve??
#4 Weld the rear 60 or run a spool?
#5 Loc-Rite in the front 60??
#6 Modify a set of hummers or get some weld on beadlocks?
These are the ones that come to mind right now and I'm sure the will be more as it progresses.This will be kind of a budget build and plan to use as many used parts as possible.The only parts I plan on buying new is seals,bearing's,gasket's and brake related parts. I have spent a pretty good wod of cash on my M1009 and dont want to do the same on this one.
The plan is to only save the firewall and frame and build from there and this turd that will be getting cut up
454 engine
350 engine
. If you really want those 5.86 gears a dana 70 would fit the bill.
