So what is CK5's general consensus on this trans? When I bought my wife's 07 Cadillac Escalade I immediately found I did not like the shifting patterns of this trans. It constantly is trying to upshift and keep the RPM's as low as possible, keeping the lid on the sweet 6.2LS under the hood that yearns to rev and make me smile. I was hoping since we had an early equipped 6L80E, that maybe newer GM's would have improved shift patterns, I found that to not be the case when I rented a '15 Tahoe that suffered from the same constant up shifting. For those of you that havent driven one, I'm talking about when you are doing 35mph in town and it wants to up shift to it's deep 6th gear, combined with tall 3.42's in the diffs. If you want quick pick up to jump up to say 45 or so, it's got to down shift 3 gears.
My 2nd issue with this trans is longevity and strength. We noticed with our Escalade some erratic issues the last year or so. Delayed engagement of reverse, flares in between 2nd and 3rd, and when 3rd gear completely broke loose and the 6.2 revved to the moon when I was passing a Prius, I knew this trans was done at 140K. Getting ready to head out to go pick up the Escalade, my builder said reverse and 3rd were totally cooked and the other clutch packs weren't far behind. $3K for a new trans. He said he doesn't think it's a very tough tranny due to the clutch sizes and sees a lot of them come in for full rebuilds at or around the 100K mark.
I miss the 4L65E. It let the LS engines rev, it's cheap to rebuild, and GM had them down to a "T" on reliability. I've seen multiple Tahoes/Yukons pass 300K on original trans.
