Thoughts on this Crew
big pappa b
3/4 ton status
Toney, AL
No pics yet but I've talked to the owner at length. 1979 GMC crew cab DUALLY, 454 (carb), 4 speed, NP205, D60/14B w/4:10's. Engine trans, and transfer case all rebuilt about 40k ago
White w/red interior, no AC, no power window or locks, missing bed and back seat, needs clutch. Older man that has owned it for 15 years (2nd owner). Prior civil service vehicle from Nevada used on the test ranges.
Truck had a flat bed originally but he let his son have the bed for his work truck.
He's stuck on $2k.
Worth it??
He said some on drivers floor. That's fairly common. I had to replace the floors on my 80 K5 too
eh 2000.00 is pushing it with no bed and a bad clutch
If its a Bonus Cab and not a 3+3 it may have never had a back seat its fairly common on Fleet trucks
Drivetrain is worth at least 2k, if he has the receipts for the work.
I would say as long as the cab isn't rusted out because floors are easy, that is a no brainer
Tranny and t-case are 10-spine units not as desirable , the 454 I guess is worth something .
I dunno I guess every place is different up here that would be $1000.00 truck
Drive train is worth more than 2k alone.
Dana 60 front: $500-$1000 depending on location
14BFF: $150-$300
Running rebuilt big block: $800
Rebuilt SM465 despite being 10spl: $250-$450
Rebuilt 205: $200-$300
That doesnt count all the engine accessories, carb, manifolds etc. Then ad in a decent crew cab (which usually bring more than standards), a 1 ton frame as a basis, roller tires, and all the little ****.
What are you waiting for go snatch that thing up lol.
I probably will. I'm going to check it out this weekend. If an 87 rear seat will work, I already have one lined up for $100
I made a small error on the description. It's a GMC, not a Chevy. Can't really see that making a difference...do you?
And he said it originally did have a back seat. It also came with a utility bed from the factory so the dually rear isn't as wide as one that would have came with a regular bed. I'm gonna have to search for pictures to see what he's talking about
You din't describe it as a dually in your first post LOL
GMC vs Chevy is minor; trim and color differences, nothing mechnical.
The utility bed vs a regular bed makes sense as to why he'd keep the old bed, as normal pickup beds are a dime a dozen. (I didn't get why the seller wanted to keep the bed at first.)
That there is what's called a "cab and chassis" truck, because GM sold it as ... well, a cab, and a chassis, i.e. with no bed. Aftermarket companies then put their flat-, stake- or utility bed on it and resell 'em at the dealer.
The C&C dual rear axles are the about same outside width as a standard single-rear wheel axle, so that the tires don't stick out wide like a regular dually.
There are two problems with this in your instance. One, they came in a variety of wheelbases, some different from the standard trucks. This means that a normal pickup bed may be a few or several inches too long or too short to fit centered on the wheel.
It also means that, depending on the tire size and the suspension, that the inside tires might rub on the wheel wells of a regular bed. Since the *outside* tires are tucked farther in, the *inside* ones are REALLY close together.
Now, it's certainly possible to tub out the wheel wells -- I know, I've done it. I don't recommend it, however, as it involves a certain amount of work and you lose the ability to put 48" wide sheets of e.g. plywood or drywall between the wheelwells.
If you are looking for a project that will involve work and some headache -- but might turn out to be something fun -- this truck is it. You could do a flatbed too, that would be cool, or you could do all kinds of custom stuff. Expect some welding, lots of swearing, and lots of measurement.
If you are looking to drop a regular bed on it and go ... well, break out the measuring tape, but be careful.
-- A
