Dafey
How do you figure it out.Mines "finalized".
for that you could have done a full resto with a big block, 4speed,205, and 1 tons..........................................
thats scary.......
Hey thanks! How hard are they to change for a noob?? Im alreay used to it and know how fast im going.Dafey,
Rather than try and explain it, I recommend you go to this link. It explains things pretty well and you can either use their tables to figure out what you need or use their math formula to figure it out:
http://www.transmissioncenter.net/sp...n_______va.htm
Or 3 tanks of gasor with how the economy is now you can almost get into an 07 2500hd 4x4 cc 6.0 for that price![]()
They are very simple to change. You remove the cable, pull the bolt holding the circle clip into place, then pull the driven gear housing out. Pop the new one in and reverse the process. Overall it should take about ten minutes to replace a driven gear.
