sandawgk5
3/4 ton status
I was cruising around the other day and threw a code, it only happens at a certain throttle position. The code is Low TPS Voltage. I have done no other troubleshooting and I have to assume this is the original from 1987. Should I just buy one from the parts store of your choice and replace it or is it possible to adjust it.
The code comes and goes and it seems to always be at the same throttle postion almost as if the resistor is damaged from use in one spot.
Thanks
Ira
Thanks
Ira
Now to get that HD light harness and the Hella H4/H1 upgrade installed...
