throw out bearing squeel?
bftank
rifle
has any body had this happen before? squeel is relatively constant depending on trucks mood, but when clutch is depressed it changes pitch. just want a better idea that this is what it is before i undertake removing everything.
if noise when no clutch pedel then input bearing or fartyher in tranny .
if noise when clutch pedel is pressed its throw out bearing .
this is a 90-95% truth but not always 100%.
If the throwout adjustment if off and it contacts the clutch all the time you will wear it out quickly and hear it under both conditions. Best to pull the tranny and replace the pilot bushing and bearing in one shot. Replace the clutch at the same time unless it is in good condition.
