Thunk
JeremyK5
Indiana
When I go from neutral to reverse, I get a fairly loud thunk. When I go from neutral to drive, I get almost no thunk. Does anyone have an idea what would cause this? I have a th350 transmission in a 75 Blazer.
That's a typical symptom of a U-Joint gone bad. Check your rear driveshaft joints for wear.
If they're fine, you should check out your tranni and transfercase mounts to make sure all the bolts are tight.
Thomas.
-- '84 K5 Blazer --
