Wherever I read it said there is 3 divots where you drill out the holes for a clutch master cylinder which is wrong close but wrong, notice the 3 divots I drilled out I knew it wasn't right the center divot is off so I made a template and this is the hole marked out to drill
Yeah divots make it easier but that center divot was way offI read the same and found no divots on my firewall. Drilled the holes from a cardboard template and it worked out well. But having correct divots could have made it easier.[/QUOTE
