Burning out old bushings out of the 64'sNice work!
Why bother burning out the old bushings if you're replacing the springs anyways?
I read the same and found no divots on my firewall. Drilled the holes from a cardboard template and it worked out well. But having correct divots could have made it easier.![]()
It has to be a 1985+ rig to have the dimples. They would not have them when they were not using a hydraulic clutch.
Martin
Nope I got pre bent lines from LMC the bends were just about perfect. And I know right just about every square body has compressor and lines removed I figure I'll hear less whining about how it's too hot from the kids lolWhere did you get that wrapped brakeline on the back axle, I assume you bent it yourself?
And just wanted to say it's awesome to see someone actually putting A/C on a truck instead of stripping it off!
Martin
I used lots of jb80 and a BFH lolHeat, lots of heat and they pop off.
