Time to clean
BIG*RED
My interior is needing a cleaning. Carpet, seats headliner etc. For those of you who still have an interior that takes a little more than a good hose out to clean, what do you use, what have you found works best to get out minor stains and dirt?
"Blue Koral upholstery cleaner with odor eliminator." I use it on everything! even in the house! :waytogo:
I use a little 27 horsepower steam carpet cleaning machine with a 4" nozzle. It's a nice portable machine. You just have to start up the F-350 flatbed that it is attached to and drive it to where you need it. I usually run 20+ inches of vacuum on a 2" hose but the wand was getting stuck on the carpet and it was quite hard to break it loose.:eek: 10" of vacuum worked better. The biggest problem was keeping the water hot, because I was using such a small amount and didn't have any high pressure hoses that were shorter than about 100'. For soap, I just used the commercial steam cleaning solution that we use on commercial buildings. I mixed it up in a spray bottle and applied it that way. The machine has soap neutralizer injected into it to disable whatever soap remains in the fabric. I think the undercarriage of my truck might even gotten a bit cleaner after doing the carpet on the floor. You asked. :D
I was going to use the small electric carpet cleaner (size of a large shop vac) that we had in our shop, but my boss had just sold that one to a friend since we didn't really use it much.
