I really hate to do this but its been sitting too long and it needs to go to someone that's going to use it. It was last used at BB 2010. Shortly after the picture I cracked the tail housing. I got it home replaced it with a new rebuilt tranny pulled the rear seats to begin a cage through a Blazin Offroad bumper on the back with some of my own tube work and then life happened.
Here's the build list as I remember it, I have a build thread somewhere.
76 350/350/205
NP205 is twin sticked with billet knobs
D60 with crossover parts mike arms and solid diff cover 2wd steering box and ORD steering box frame were installed just before BB 2010
14 bolt rear with lockrite DIY4x diff cover and disc brakes with eldo calipers but the ebrake is not hooked up.
4" lift springs in front with a ORD shackle flip and 56" springs in the back
35" general grabbers on 17" steel wheels
York OBA compressor mounted but tank and lines need to be mounted and plumbed
Bazin offroad front bumper with Warn 9.5TI winch In cab winch control plate and wiring ran but winch needs to be be connected. I had a Check engine light added to the plate when I had this made.
DIY4x tube doors
6 point Cage out of a 77+ easy to mod just trim the b Pillars and drop it in
Soft and hard top
Everything needed to convert to TBI. I pulled everything out of a 90 as well as bought a new wiring harness tank fuel pump efi hose cap rotor.
Front seats are out of a 2003 Silverado, buckets with center seat and console.
Carpet still looks brand new
Stock near new goodmark bumpers included
THINGS IT NEEDS:
I put a new heater fan in it 5 years or so ago and for some reason it stopped working, may be just a fuse.
I bought a rear seat but when I put the buckets in I didnt put in the chrome floor brackets so you'll need those. Buckets are gone.
Needs a new glove box, hinge gave out.
Has dual batteries both are dead, although I do jump it on occasion to keep the seals wet.
Clear coat is peeling
I'm sure I'm missing some stuff but this is the bulk of it. I can deliver for the cost of my fuel. I'd like to see $5k willing to entertain offers of trades for ATV's (I need 3 so the kids can ride with me) or a boat.
76 350/350/205
DIY4x tube doors
Soft and hard top
THINGS IT NEEDS:
