CherryK5
Should i buy new oem stuff or build my own for almost the same price with heim joints?
What are the pros/cons of each?
DO NOT use heim joints if it is a DD. Heim joints are single sheer and not nearly as strong as a TRE/DLE. I bought a HD drag link from ORD and a HD tie rod from WFO and both use TRE's.
well that's just it
you need it set up correctly to hold the heim on both ends, not just one.
An HD quality heim with some kind of boot or protection for it would be nice
but when it comes down to it, tierod ends are low maintenance, strong, and convenient at any autoparts store for replacement. Hence, good for DDers. Easy to find for trail fixes too.
Did you use cheap heim joints?
I keep bending those adjustment sleeves and killing my alignment on my tie rod..
A nice heim joint setup seems much stronger IMO.
My heim joints are double sheered...
But yeah, if you want to run heims get some double sheer arms and do high/crossover and a drag link that wont stop you from turning when drooped...
Not many people take the effort to do that but even then a Heim joint wears out ALOT quicker than any TRE/DLE will.
ditch the sleeve and get a tie rod that is threaded, with a slit cut in it. then use a clamp....
I have never used a Heim joint because of the failure rate and being in single sheer they ARE NOT anywhere near as strong.
Ditch the factory tie rod that uses the adjusting sleeve in favor of a length of DOM tube that is threaded on each end (right hand on one end and left hand on the other so that you can adjust without having to remove either end) then use the proper TRE for your application. This is the STRONGEST method available.
Stock TRE's are single shear. The big difference is they are in a tapered bore in the knuckle to insure that they don't have any play in that portion of the system. If you drill a hole in the knuckle for a bolt (say, if you were going to heims) it will have a little slop that will get bigger and bigger as time goes on.
Also not true, depends on the size, material etc of the heim chosen. They could easily be stronger than the stock TRE.
The big reasons to stay away from Heims are that they wear out much faster than the stock TRE's and they aren't meant to be mounted in single shear which means either deal with steering that may not be tight (and will wear out the knuckle eventually) or make a tab on the knuckle to allow double shear.
I already knew all of that.
I still disagree that ANY heim mounted in single sheer is stronger than a TRE.
Well i might just double sheer it.
That sounds like one of those "do it while you have your **** apart" situations.
