COCHEV
So my work truck failed its first attempt at the DEQ last night. The test said my Hydorcarbons and carbonmonoxide levels were too high.
The truck- 82 3/4 ton with crate 350, 1406 edelpuke, stock exhaust manies.
I went home and pulled the cap (2yrs old) It showed normal wear, but not toast by any means. Pulled a plug or 2 and they could possible use replacing.
So I plan to do a generic tune up. Its been idling a little rough so maybe the plug wires too
I've had it for a little over 2 years now and its run so well i haven't messed with the plugs and wires.
Should I mess with the timing or idle mixtures? If so, in what way?
I've had it for a little over 2 years now and its run so well i haven't messed with the plugs and wires. Should I mess with the timing or idle mixtures? If so, in what way?
