Tire manufacture date
Yeah, this 32psi stuff's for stock DD cars. Trust science not numbers stuck in your head. The bigger the tire, the lower your air should be.
What would you suggest or drive if this were your set up?
I already said it. I suggest doing math/measurements on the actual equipment in use, not some arbitrary number that sounds right.
When I had tires that size I usually went down the road at about 25psi, bit since I have a different setup...
