Tire Pressure
k20
3/4 ton status
Mineral Springs, NC
Hey all, real quick question, I noticed today, on my SSR's, on the center lugs, they seem to be cupping a little, the rear of the lugs (the rear when they are on the top of the tire, when that same lug is on ground it would be the front). Is this a problem from too much air or too little? I am running 32 front and 28 rear, the rear look fine, should i drop the front to 30 and see if that helps? Thanks. Chris.
Tires cupping has nothing to do with tire pressure.
You need to rotate your tires, and you need to have your alignment checked.
