First some background info: I have a 91 K5 that I purchased with 6 inch spring lift and 35 inch tires. Everything else stock. Leaf springs are typical old school lift style that are overly stiff. I am planning my build for this truck and want to use a linked suspension front and rear. This will be my first linked suspension. I live in mid-NC so it will see use on everything from pure sand and mud down east to the muddy rock trails you get in NC, TN, and KY. I want to keep it street legal and will drive it to wheel it. I want to keep it "full size" and not get into dovetailing but am planning on extensive trimming to the wheel wells to accommodate larger tires. My current thinking is to go with tires in the 38 inch range. I think I can do the wheeling I want to do without going to a tire in the 40 to 44 inch range. This will keep the truck lower to the ground, it will be easier to use on a daily basis, etc. So I have a few questions.
1. Realistically, what is largest tire you can trim out for and still get under the truck (with reasonable suspension travel), without lifting the truck so high that you can't really wheel it? (Afterall, you can design a suspension to run 44 inch tires with no cutting on the body at all. And the truck would be 5 feet in the air and tip over the first time you got sideways with it.)
2. How tight is the relationship between tire size and the suspension design? Suppose I have a link suspension that was set up with 38 inch tires in mind and I decide I want to go to a larger tire, say a 40 or 42. Can that be done without changing the length of the links, spring height, shock length, etc.?
