mostwanted
Please school me on this subject. What tire ratings should I use on a suburban that is going to be towing a K5 crawler on a wood deck trailer? I know load range E would be ideal, but it seams as if they don't make that range in the styles I like.
. So 4 x 3,000 = 12,000 lbs. The general guideline when pulling a bumper pull trailer is 10-15% tongue weight. So assuming the Suburban weighs 6,000 lbs. and 50% front to rear weight distribution, and then add 700-1,000 lbs. for trailer tongue weight and you only have around 4,000 lbs. on the rear two tires, which are rated for 6,000 lbs. total.
