I don't know about Alaska,we get some bad snowfalls here too..
I've had to plow quite a few bad Nor'easters that dumped over 2 feet ,and wasn't able to get out there and "plow with the storm" as the Fisher sticker says you should..when we get 60+ mph winds and 2-4" per hour snowfall rates,most of the time your better off waiting till the storm starts dying down before going out to battle it..if your at work while its snowing then you have to wait till 5 pm to go plow your driveway,by then its usually as deep as it'll get..
I have had 36" of wet cement snow fall here at least 3 times,in less than 24 hours...the Blizzard of '78 dumped that much too,but it had hurricane force winds too,which made drifts well over 10 feet high...luckily our driveway had "only" about 38" fall and it wasn't drifted much over 4 feet in a few spots..still took a front end loader to get a path made to the street..couldn't drive for a week,they "banned" us from driving unless we had special permits..
I can see where low range would take some strain off the transmission,but with the wheels so easy to spin,and the added torque to the driveshafts,u-joints and diffs,I'd say breakage is more likely in low range than high range..
..Winters here suck enough...
