10k is the magic number for me because at 10001 I get in the higher bracket that requires extra regulation.I scrapped a 80 k30 with a 12k gvw 1 time . Had badges on cab for trailer towing special 12,000 gvw . And seen some 2wd trucks go to 15k or 16k but not in person .
SWEETK30 - do you recall what the spring pack looked like on that 12K K-30 ?I scrapped a 80 k30 with a 12k gvw 1 time . Had badges on cab for trailer towing special 12,000 gvw . And seen some 2wd trucks go to 15k or 16k but not in person .
oh we get it per bracket in weight also for sure here .10k is the magic number for me because at 10001 I get in the higher bracket that requires extra regulation.
I had an 88 c&c with a utility bed, it was a 15k and had a 12leaf spring pack no overload.SWEETK30 - do you recall what the spring pack looked like on that 12K K-30 ?
Also, was it a cab chassis or truck with a bed?
I’m just curious about the spring configurations - my old 83 crew cab DRW K-30 was rated at 10K and had the usual nine leaf pack plus an auxiliary leaf but my other 83 cab chassis K-30 has a 15K rating and has a ten leaf stack but no auxiliary leaf - on the 15K stack the following leaves are longer and rest directly under the main leaf eyelet compared to the 10K pack that does not support the main leaf in the same manner.
Just wondering what the 12K pack was like?
Added pics for reference - the 83 C/C K-30 15K pack and the other two are also C/C’s ( R-3500’s 1988’s ) one rated at 10K and the other at 15K.
Thanks, Tom
did the ad state it ran when parked, ha.
It did run when parked and then he pulled the heads, and that was 34 years ago.did the ad state it ran when parked, ha.
Don't get me wrong I spent my early days in the middle east on the coast and I never scrapped a vehicle. They were too expensive to replace and too cheap to fix so we did.I see you’re not doing anything but pulling the good parts. Probably best but restoration is possible as long as you got enough time or money or skill or all three. Lol. Glad you got your moneys worth either way. Pa is not good on vehicles either. Always fighting the rust.
Am I the only one that knew he wasn’t serious about rebuilding this truck?
