iPhone for me
regulator will be NEEDED for the system from edelbrock .
58 psi system https://www.summitracing.com/parts/edl-17401Any particular one? Link?
Me too. Apparently the 381 is just under the LPH rating. Of course that is a full throttle requirement....
I'm very interested in this. Last time I towed the camper up to the mountains, I really wondered if it wasn't getting enough fuel at the higher rpm pulling the passes. I haven't had a chance to try again now that I can see fuel pressure in the cab.I’m probably not using enough fuel for it to be a concern then.
For BroFlow? I would think you would be closer to $2500, but I'm not sure what you're looking at doing along with it.So roughly this could be if I install it myself about $3000.00 ballpark....
If outsourced potentially upwards of $5000.00 ballpark?
If fuel pressure drops off at the higher RPM would that indicate the pump isn't able to keep up?
I'm running the factory TBI hard lines and filter. But there could be a restriction at the tank selector valve. I know it's okay for the pressure, but come to think of it I've never seen anything listed about flow thru them.Assuming your filter, regulator and lines are in good shape then yes, your pump would be the problem.
Flobro and fuel system... yeah about $2500 for me to do it. Which would probably take 1-4 months for me to finish.For BroFlow? I would think you would be closer to $2500, but I'm not sure what you're looking at doing along with it.
Where did anyone say an LS was difficult? I sure missed that.Got dang guys. An ls swap is simple stuff. Y’all make it sound so difficult. It is literally the opposite. DM me your contact info and I will share whatever info I have. I have no problem helping a fellow ck5’er. My swap is running like a dream and I want nothing more than helping more squares hit the road.
That was my responseIt’s not all that bad. But you will need and O2 bung hole
Nope. Already helped with my tranny and 203.That was my response
wouldn’t be the first time team Ck5 helped someone work through an install
What's your fuel delivery system set up for? GM TBI is much lower pressure than FI or even an aftermarket TBI system.
Stock ,stock,stock,for a 76 ,, for 454, thanksWhat's your fuel delivery system set up for? GM TBI is much lower pressure than FI or even an aftermarket TBI system.
Agreed that it's not that difficult. With the swap brackets the LS drops in like any small or big block.Got dang guys. An ls swap is simple stuff. Y’all make it sound so difficult. It is literally the opposite. DM me your contact info and I will share whatever info I have. I have no problem helping a fellow ck5’er. My swap is running like a dream and I want nothing more than helping more squares hit the road.
