I’m just teasing... no harm was meant.You can make text size larger but no reason to antagonize further.
not antagonize me . . . its just how will people search and find the info later who have no idea the new name some have given it . thats my point here . i sometimes have a hard time finding stuff here i know i posted and words i used . so why make it any harder is the point i was making .You can make text size larger but no reason to antagonize further.
I was just reading up on the advantages to this SEFI system...
This about right? So it fires when needed and doesn’t take a crank Revolution to increase speed?
https://m.carsdirect.com/used-car-buying/how-a-sequential-fuel-injection-works-pros-and-cons
I personally would be more interested in the fuel economy aspect. Not that I chase fuel economy, but having the power when I want while getting a little more economy when I'm not using the power is my thought.Well, I suppose. But how would an average person measure that in any practical manner? Think about how many times the crank is turning at idle.
GM did this experiment with the LT1's in the 90's, when they went from batch to sequential on the same engines, without any other changes. Sequential was worth maybe 5HP. Sequential vs. batch should not be used as the determining factor when selecting a system. If that was the only difference, and the price was the same, no brainer.
Seems like with aftermarket EFI, I never seen any discussion about MPG. Just drive-ability and throttle response is all I seem to see.I personally would be more interested in the fuel economy aspect. Not that I chase fuel economy, but having the power when I want while getting a little more economy when I'm not using the power is my thought.
I honestly hadn't really thought of any possible power increase, just the thought of it being able to meter the fuel more precisely.
I just believe that if the engine runs cleaner by better management and mixture of the fuel and air, there should be benefits in economy as well as the oil stays cleaner for a longer time. It has been proven that excess fuel and the carbon that is created by combustion can degrade the oil.Seems like with aftermarket EFI, I never seen any discussion about MPG. Just drive-ability and throttle response is all I seem to see.
Look at the MPG's of the trucks as technology has progressed. It *really* hasn't increased like you'd expect over time.
Vs. a carb, I'd really argue drivability as the number one benefit to the swap ... how many miles is it going to take for you to break even for the cost of an injection system? A ton.
Bingo Dave.I just believe that if the engine runs cleaner by better management and mixture of the fuel and air, there should be benefits in economy as well as the oil stays cleaner for a longer time. It has been proven that excess fuel and the carbon that is created by combustion can degrade the oil.
I don't see hotrod guys discussing fuel economy because it's shunned by the "power guys". But if your ride guzzles gas so fast that you can't afford to go play, what's the point of having it? So if small gains can be made in fuel consumption, it should help stretch dollars in fuel and oil, since the oil shouldn't degrade as quickly either.
With my FAST EZ EFI I can lean out the cruise AFR on the fly. I tried it on a road trip and it actually worked. When I had a carb the best I'd get was 11mpg, with the FAST set up normally (14.0 cruise AFR for best responsiveness) I get 13mpg, and with lean cruise at 15.0 I got 15.5mpg.
Not to go too off topic, but what is the strategy within FAST to run lean? GM (ancient TPI stuff) had a few parameters that needed to be met to go lean cruise, which were pretty stringent and on/off even under the same conditions, because ultimately, one of the problems running lean is heat being absorbed by the piston. Outside the NOx problem of course, but GM got caught and it was never released in the US in any case, even though the code was still there for it.
Great insights and I’ve learned a lot. I’m probably goin efi down the road. The ultimate decision for me is ProFlo or Holley. I hope to tackle this project this year. I need to set aside some money. I had to do the shocks first, they were horrible and my engine is fine for now....so priorities.
For my truck needs and what I’ve read coupled with cost. I’m still learning towards Holley but I have time to kick this around.
