To sway bar, or not??
steve_kibbe
Spartanburg, SC
Going to URE next weekend...
Stock K5 running 33" tsl's
Should I take the swa bar off for the weekend or not?
Depends on if you mind some minor fender damage from the tires hitting. Personally I would take it off for the weekend
just toss it alltogether, i lost mine about 3 years ago. you will notice a little more sway, but not enough to make you want it back on.
yes they fit with no lift. they are like a shackle on the end of the swaybar were it bolts to the spring plate.
yup just chuck it.... took mine off last year. it sways a bit now but it feels sweet!!!!!!!! just slow down on the winding freeways and street corners
or you can just do what i did and get a lift kit with the invisible sway bar... rough country = stiff as hell, i can take corners faster now then i did with a sway bar.
