OK...Need some advice. I'm in the market for one ton axles to put under my overland 'burb I'm building up. I am in the process of accumilating a 203/205 doubler and will be running behind a sm465. I will be running H1 wheels and tires so 37", so they match my M1101 trailer. I want DRW front axle since backspacing on stock wheels. For gearing I want 4.56 gears.
My question is....For what I want DRW and 4.56 should I buy a 1-ton c&c truck, thats been stripped of body parts, that has 4.10 gears and DRW and sell the 14 bolt rear thats to narrow ($1000 is what owner is at now)? Or find a CUCV axle with a 4.56 and convert it to DRW? As these get installed B-52's and rear flip will be installed. CUCV tons are not the easiest to come by here in North Texas....they normally go pretty quick, not impossible.
Thanks.
Thanks.
