Tons of parts. Axles/gears/trim/and more
clhenry
Glenwood Springs Colorado
If you need odds and ends i've stripped 2 of my trucks and have lots of odds and end parts. If you need something feel free to ask if I didn't list it. Most parts are grey or white
I have virtually no sheetmetal (sound familiar :) ) One of the members on here (diablo1) and I did a round robin of truck parts swaps and put my old truck on the ground again, put in my sons capable hands, in 6 months he proved he was capable with one wreck and one blown tranny. Now POS as she was known (below in the blue and gold now) is on to greener pastures and soon the crusher.
Windows for doors both sides
wing windows
2 Toppers one mostly white, the other mostly black
mirrors
tail light assembly
marker light assembly
some head light assembly for quad GMC style grill
4 core radiator less than 2 years old
4 core radiator about 6 years old (8k miles)
power window wiring and motors
grey door panels
door sill plates
window regulators
radiator over flow tank
windshield fluid reservoir
upper radiator support brackets
make an offer on all the above for what ever you might need
Turbo 400 - good for core - make offer
NP208 transfer case - rebuilt 8k miles ago - $125
350 engine complete and running (non- tbi) - $200
ORD frame support for steering box - SOLD
ORD sway bar disconnects - $60
Drop steering arm 4 inch - Sold
Complete Dana 44 with 4:56 gears and 8 lug from hub to hub- sold
Ring/pinion/open carrier 4:56 ratio for 14 bolt - sold
Complete matched set of:
14 bolt ARB locked 8 lug rear axle
10 bolt ARB locked 8 lug front axle with brake lines (hub to hub) - asking $1700 for the pair
Complete set of stock 1/2 ton axles with 4:10 radio on 6 lug - make offer
All Parts are near Glenwood Springs Colorado, I can and will ship, if you want a freight estimate check with UPS based on Zip 81601 and you can likely estimate the weight to get an idea of what it might cost.
any chance you have a k5 tailgate? how much you want for the dana 44 and 14 bolt carrier?
Tail gate, one of the few pieces of sheet metal I have - come get it, it's yours. It's not immaculate and it is for a blazer, is that what you're after?
The Dana 44 and the gears for the 14bolt- i'd like to scare out $300. Pick up is pretty much the answer on this as freight would be nuts.
Does that tailgate work? Roll up and down and all that? Thats what I am after for sure hoping for something that at least rolls up and down. Hopefully I can scrape together the $300 for that dana 44 and 14 bolt gears, it wouldnt be for 2 weeks so we will see if you still have em. Thanks!
Let me know on the tailgate and I might come get it.
If that is the bolt in box brace for the 81-91 Ill take it.
Curtis
P.S. Shoot me a PM with your paypal address.
The Grill and most sheet metal
Sorry to say the grill, and virtually all sheet metal are toast.
What wasn't marginal due to rust now looks, well, it was hammered pretty hard when we stripped it and took it to the high school for my youngest son's band fund raiser as a car smash victim. It held up really well and we hurt some ego's that thought they were going to put the sledge through the truck. Only to be thwarted by good old GMC iron.
Maybe i'll take a couple pix just for fun to help explain what really happened. It was both sad and a blast. Took the tax deduction for the donation as the body wasn't anything.
I r not the smartest in the lot, but I can be taught. Just don't tell her.
Found the update, have pricing updated, sold updated and added an image to explain: no sheet metal
This is my old truck that we put back on the ground and put my youngest son in. Promply in about 6 months he burned up the tranny. So we donated the chassis to his high school for his band program as a fund rasier. Hella fun, kind of sad. Broke a few ego's when they thought they were just going to put holes in it. Good old fashioned GMC iron took a beating and came out pretty good. rasied 400 bucks at 2 whacks for a buck, you do the math!
i think i was 1st on the steering brace but i had an very unplanned event(see my post in lounge) & i have to bow out regretfully..sorry
Sorry Blazin, I never intended to swipe the box brace from under you. :doah: I hope everything works out! You know people get what is coming to them in the end!
Curtis
Are the 10 bolts 28 or 30 spline?? If they are 28, how much to just take the carriers with the 4.10s in em. I just want to avoid shipping on huge axles when i have the same ones sitting under my car. thanks!
Good question on which spline, i'll crack lids this week and get an answer. Freight even on carriers/ring/pinion would still be crazy. But if you are going to get them anywhere, shipping is what it is.
I'll get back with you if it's what you're after.
Thanks
Thanks
Yeah i am interested if the splines match up. are they both open carriers, or any traction devices?
The price of a new R/P is like 300$, and I just am trying to find the cheapest way of throwing in some gears for my new 35" tires. No money left over :doah:
I'd be interested in these:
tail light assembly
What parts are these? The whole assembly including wiring? With or without lenses? What shape are they in?
Easiest would be a picture so I could see them.
Tail light assembly, got em. I'll work on pics for you- 20 bucks for the inner and outer housing assembly.
Wiring, how much of it do you need? I can chase it back to the nearest factory splice or all the way down the frame rails. It was fully functional but I have done two dirrerent repairs to it. One in the rear due to a lousy trailer harness splice, one in the front due to mice and the marker lights. Both were done cleanly with the new style heat shrink glue sealed splices with a complete new donor section of wire. SO it should be good for the go. Just need to know what in detail you need.
Marker lights on the sides, not worthy of much on one, acceptable on the other, i'll check which I have. 5 bucks each?
Marker lights from the bumper assembly - see images - 5 bucks each
Quad lighting up front, it has it, I have the bezels, lights, wiring but not sure the buckets into the radiator support are all worthy, some may be shot? The surrounds on the lights should be viable too.
