Tons of parts. Axles/gears/trim/and more
ORD disconnects. i'll send you a pic to be sure it's everythign you're after. Call it a deal and ear mark them as sold. I'll send a pic shortly on this as well.
81 head and tail light odds and ends
Does this answer your question, it appears I only have buckets for the drivers side lights to the radiator support.
Let me know if you need complete wiring or just pieces parts on harnesses. Options are a plenty.
I'd be interested in these:
tail light assembly
marker light assembly
some head light assembly for quad GMC style grill
What parts are these? The whole assembly including wiring? With or without lenses? What shape are they in?
Easiest would be a picture so I could see them.
Updated images posted
Jsut a quick note that i've got new images for you, see if this helps
tail light assembly
Yeah, the tails are about the same condition as the spares I have. Not the right type of front lights though. I have an 89.
Good luck with the sale.
updates on whats left!
If you need odds and ends i've stripped 2 of my trucks and have lots of odds and end parts. If you need something feel free to ask if I didn't list it. Most parts are grey or white
I have virtually no sheetmetal (sound familiar :) ) One of the members on here (diablo1) and I did a round robin of truck parts swaps and put my old truck on the ground again, put in my sons capable hands, in 6 months he proved he was capable with one wreck and one blown tranny. Now POS as she was known (below in the blue and gold now) is on to greener pastures and soon the crusher.
Windows for doors both sides
wing windows
2 Toppers one mostly white, the other mostly black
mirrors
tail light assembly
4 core radiator less than 2 years old
4 core radiator about 6 years old (8k miles)
power window wiring and motors
grey door panels
door sill plates
window regulators
radiator over flow tank
windshield fluid reservoir
upper radiator support brackets
Turbo 400 - good for core - make offer
NP208 transfer case - rebuilt 8k miles ago - $125
350 engine complete and running (non- tbi) - $200
ORD frame support for steering box - SOLD
ORD sway bar disconnects - $60
Drop steering arm 4 inch - SOLD
Complete Dana 44 with 4:56 gears and 8 lug from hub to hub - SOLD
Ring/pinion/open carrier 4:56 ratio for 14 bolt - SOLD
Complete matched set of:
14 bolt ARB locked 8 lug rear axle
10 bolt ARB locked 8 lug front axle with brake lines (hub to hub) - asking $1700
Complete set of stock 1/2 ton axles with 4:10 radio on 6 lug - make offer
All Parts are near Glenwood Springs Colorado, I can and will ship, if you want a freight estimate check with UPS based on Zip 81601 and you can likely estimate the weight to get an idea of what it might cost.
will the ord sway bar disconects fit my 89 k5 it has a 10 bolt now and i am about to upgrade to a d60 will they still work then? and is everything there
disconnects
They should work just fine on your 89. I've used them on my 81 and my 91 blazer/Jimmy
Can tell you that on the 10 bolt should bolt right up. And odds are on your 60 as well. So long as you aren't running cross over steering. If you go cross over you probably will have some fabrication and or clearance issues. I went Dana 60 with cross over and hydro assist with out any sway bar and it gets by ok on the highway.
There are pictures on here of the parts sitting on my work stool for you to check out. Ndaucally you provide the actual stock swaybar and these attach to the sway bar, frame and your stock plates to your springs come off. These go on. And you're done. 12 bolts total with 4 at each spring to axle clamp and 2 at each sway bar to frame mount and you're ready to roll.
Let me know if you have more questions. Any weird typos are courtesy of my blackberry.
Thanks!
i am kinda broke right now lol just had trans built again and i don't mean to sound cheap or anything but i would give you 40 for the sway bar disconects shipped to 77327 i know they are worth more than that but that is about all i can spare right now
Disconnects
If you're only kind broke, you're doing GOOD!
No harm no foul, cheap is the "chic" :whistle: i've got two others in line on them kind of waiting for them to come through, but i'll put you on the want list. Thanks for asking!
