hmatiak
Just got a new tow pig.
Planning on just doing a cam swap and intake and exhaust as the truck is very low miles. Already had this: http://www.summitracing.com/parts/CCA-K11-238-3/ cam for a carb 454 build i had planned, but now im thinking of putting in the new truck. I was told the lobe seperation was no good at 110, that it would be better at 112. Anyone with a similar setup? Truck is 1988 TBI 454.
I posted the PROM programming for a 454 cam similar (but not exactly the same) to the cam profile in your original post. The picture below is a compare between the original PROM program and the modified PROM program. The ("+") / ("-") numbers are increased / decreased values of the new PROM programming compared to the old PROM programming. The ea$y way / low co$t way to change a 454 TBI cam is sell the 454 throttle body and install a quadrajet.
