My new engine for the C10 recommends a 2200-2500 stall. I've not messed around much with converters.
Are there downsides to a higher stall converter?
Would a converter like recommended cause issues if I tow a 4500lbs camper?
Some of the converters I've looked at in that range say it's based on a big block and a small block would be 300-500 RPM lower. Should I look for a 2500-2800 stall?
Any other thoughts?
Any other thoughts?
