THRILLBILLY
Hey guys, it's been awhile since I posted anything but I'm back to working on the Blazer and have come to a crossroads on what to do and how to do it.. I searched some but couldn't really find a similar back story so here it goes:
We put the new motor in which sounds awesome. Runs perfect at idle and throttle response is on point. But we seemed to overlook a key component of a high performance motor, the torque converter... Obviously a 11:7:1 compression race fuel 355 is going to fall on its face with a stock converter in place (which it does) so my question for you guys is, with the motor setup I have in the truck setup I have, what exactly am I looking for in a converter?
stall speed, overall size, lockup vs. non-lockup? There is so many factors that come into play when choosing one like vehicle weight, cam specs, gearing, etc. that have kept me up at night reading so much I don't even know where to go from here.
So if you guys wouldnt mind, here is a quick overview of everything I got in the motor/drivetrain to help you guys help me out!
355 sbc
timing set at 34*
.125 dome top pistons
200cc 2.02/1.60 aluminum heads with .600 lift springs
1.5 full roller rockers
single profile hyd. flat tappet cam 301/301 adv. - 247/[email protected] - .525 lift - 110* lobe 106* center
750 vacuum sec. Quick Fuel carb
hurricane high rise single plane intake
built 700R4 with 208
44" tires
4.56 gears.
Thanks guys and let me know if something seems out of wack or doesn't look like it will work. I want to get power to the ground fast for the mud bogs and who better to ask than CK5!
355 sbc
timing set at 34*
44" tires
4.56 gears.
