badmix
Well, my last thread gained some info. But here is the latest. Just got done with a 2hour interstate run. The convertor at one point did lock up, my RPMs dropped 200rpm and the tranny temp gauge dropped a good 10degrees. I tapped the brakes to see if it would unlock, it did, only to never lock up again for over an hour I eagle watched the gauges, it never locked. So, I know it is capable of locking but why wouldnt it?
I need to know what to check, change, look for etc etc.
If its the solenoid, how hard is that to change? Anyone have a diagram as to where it is and how to access it? I have no idea how to check the firewall vacuum pressure switch. and the switch under the dash that the brakes activate.
Is the switch under the dash strictly to Dissengage the Cruise and the TCC? It has a long threaded body, how is this suppose to be adjusted or setup properly.
Im sure someone has to had this problem on their K5 at some point. Just trying to figure where to look before I end up down at the tranny shop.
The truck is '84, 305cid, 700r w/ 137k miles. Could the solenoid just be wore out, could the convertor be worn out?
***UPDATE***
Well, I hooked up my lil LED light to the 12v wire at the tranny. That was interesting. Its amazing when that thing lights up. But Im guessing me monkeying with the connection at the tranny and under the dash Ive got it working. I just drove 2 hours and it locked and stayed locked. I did unlock it on the freeway and it took a few minutes to lock up. Also itll lock up at low speeds which surprised me. So, im going to clean up the connections better at the tranny and may just wholesale replace the TCC / CC cancel switch under the dash, Im sure its OEM stuff and probably getting wore out. I plan to service the transmission, I got a nice billet pan with drain hole. Might as well change the fluid and filter and put in the new plan. NOW. should I replace the solenoid in the tranny or leave well enuff alone?
thanks for all the help, I do sincerely appreciate it. You guys are a wealth of knowledge.
***UPDATE***
