garydan
I just replaced the sector shaft in my steering box and installed the new pitman arm. Do you have to torque that nut (the big one attaching the pitman arm... not the adjusting nut on top) to a specific torque?
I'm not going lie, I get it as tight as I can with my Ingersol-rand 1/2 drive impact, and call it.
I always tighten it as much as I can with a breaker bar.
Just come to Blazer Bash.
We have the mobile pitman-arm-nut-check-and-tighten service gang... covers all of Slickrock campground
The proper torque spec is 180 ft/lbs.
I've got to hear the story behind this one...![]()
my left arm has a torque rating of 500 ft/lb and my left negative is rated at Negative 320 ft/lb so i hit it spot on every time![]()
I think it was Travis (mtnman), Jason (Jason4x4) and Paul (Vikingwarlord) who walked around the campground one night with a torque wrench (and a six pack, I believe...) and checked trucks w/ x-over steering. On pretty much every truck they checked the nut was loose to some degree![]()
Unfortunately, I don't even drink and I'd probably been running around with them.
So what your trying to say is that the proper torque is 180 ft/lb's?![]()
