Torsion bars
bigbadchev84
Hermiston, Oregon
I am just now getting around to replacing the drop brackets for the torsion bar crossmember. I have never dealt with this suspension before so I figured I better research before jumping into this. These Are the lift kit drop brackets that need replaced, Is it gonna be as easy as unbolting 1 side at a time and throwing the new one in?
you need a torsion bar tool to hold the arm for you to remove the adjuster bolt .
then count the turns till bottom out before unloading the bar. and put them back the same. then for best bet get the alignment checked . as to high or low will throw off everything.
let me know if you need more info.
