towing question
99firehawk
I know theres a towing section but figured Id get more responses like this.
I have a 83 k5 with 35 bfg ats and 6inchs of lift. Im considering pulling a pop up camper 2200lbs 14 ft. Ive never towed with a lifted truck before, Im going about 80 miles, Im in no hurry and have no problems doing 50-55 . Think the ol k5 is up to it? (fresh350, fresh t350 with a towing shift kit and 100%fresh brakes master->wheel cyl. and suspension. )
tia
It is up to it if you can keep the rear of the camper off the highway. Better look into a dropped hitch for that thing.
(35's on the trailer would solve the problem and be sweet /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif) /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif
towing that load will be no problem with your ride but you will probably want a drop hitch.
im thinking you might need a 8" drop thingy majig. (I dont think a "drop hitch" is the proper term- as this refers to the whole hitch being lower.
I stand corrected..you need a drop thingamajig. /forums/images/graemlins/wink.gif
Most people call them drop hitches... and that is what you need.
Other than that, you should be fine with such a small load behind you.
ya i have always called them droped hitches, but from now on i will use thingamajig /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif
Thanks for the respones guys, Im on my way out now. I have a 7 and 5/8 droped thingamajig and the trailer only sits about an inch higher in the front when its hooked up. I was more concerned with how a lifted short wheel base truck tows, considerign my towing experince id with a gmc club cab dually and a f250 diesel long bed.
Wish me luck gentle men
Once you have your drop thingymajig, your all set. Depends on how you did your rear lift- The softer the spring, the more issues you will have-. If you have some stiff rear springs, then your all set. /forums/images/graemlins/thumb.gif
With a 2,000lb rolling load you shouldn't even notice it's back there. Especially with a low profile pop up.
I looked it up eariler, the thingymagig is called a "Hitch Ball mount". More specifically, he is looking for a "Drop hitch ball mount" /forums/images/graemlins/screwy.gif
You might not notice it back there, but I can tell you from personal experience that flexy springs and pot holes do not make for one fun towing experience.
