I just haven't had much time recording data with TunerPro yet to really help there but Dave is very good with it.
As you probably know TunerPro also gives you the tools/ability to modify your data recordings along with making definition files etc... I was so used to watching the BLM table while driving (yes I know that's stupid) actually just a peak, then stop and look, then peak as to get the blank spots to fill in by getting the right manifold vacuum vs RPM. So anyway I used the features available in TunerPro to modify the XDF file and built a MAP vs RPM table just like WinALDL and it worked!!!
I had help from Robert Sarr who builds most of the definition files used in TunerPro and he built the origanal $42 mask so I have to give him credit for all the work he shares!
I'd share it with you but it's not the right XDF for your TPI ECM... what XDF do you use?
