TPI + EZ EFI kit for sale
Z71paramedic
Wait....What???
Lakewood, WA
Hey guys, I'm trying to get rid of some small block stuff that I put together before I decided to go big block.
I have a (nearly) complete Tuned Port setup that would let you go from carb to EFI. Included in this is:
Tuned Port intake from 90 Trans Am - lower, runners, upper intake, fuel rails
Holley throttle body
FAST EZ-EFI complete kit - engine harness, computer, scanner, wideband o2 sensor, all 5 engine sensors, fuel pump, fuel pressure regulator + gauge
Will come with the serpentine brackets/accessories
Only needs a distributor, gasket set and fuel injectors to run it (plus the right heads).
I also have a fresh set of 193 heads, but I figure that shipping will make those not worth the cost as they are stock heads. I'm sure you can find some similar or better nearby.
I'd like to get $1,700 for the setup + shipping. I have $1,300 in the FAST kit alone and the throttle body that comes with the intake is $450 at summit. If you want the heads, I have $300 in them, I'd take $200 for them. I'd like to get this stuff gone. The wallet could use a break after the big block stuff...
I am interested in the Fast EZ-EFI complete kit. I have a 383 stroker, but I think the basic kit for a 350 would do just fine. How much would you be willing to part with this? How much do you think shipping would be to Colorado? I am also sending you a pm just cause :D. Thanks!
