BCCHowdy
Registered Member
Hello!
I'm a new member and recently acquired an '85 K5 Blazer. I have a freshly rebuilt 350 to go in it along with a TPI fuel injection system and I'm having trouble finding a good location for the inline fuel pump I purchased. I'm also concerned about the size of the return line being 1/4".
The fuel tank has 3 lines. Supply line is 3/8". Vent line to charcoal canister is 3/8" (5/16??). And the return line from the original mechanical fuel pump is 1/4". If I remember right the vent line has an orifice on the tank side which would greatly restrict flow and inhibit use as a return line. I put about 20 psi of air to the vent line and there's quite a bit of back pressure. The 1/4" return line seems to be ok as far as back pressure in comparison to the vent line, but I'm concerned it's not big enough. I purchased the walbro 255lph high pressure pump and I'm concerned the 1/4 return line will be too small driving pressures higher than what the pressure regulator on the fuel rail will manage.
Does anybody know if the 1/4 line will work as a suitable return line? My alternative is to plumb the pump in a loop with pressure gauge and see what it does with nothing else hooked up.
I'm having a heck of a time finding a location for the inline pump. If anyone else has done this type of conversion, where did you put the pump?
I've done a carb to TPI conversion in the past on an '84 GMC halfton dual tank system. I had a high volume low pressure pump mounted on the passenger side wheel well in the engine bay pull from the tanks and push to the low volume high pressure fuel injection pump. Sounds kinda silly, but it worked flawlessly. I'd like to do a cleaner install this time around with the fuel pump back by the tank. I'd like to avoid installing a new tank and in-tank pump and new fuel lines (proper return size) if I can get away with it.
I intended to put this post in the 1973-1991 K5 Blazer | Truck | Suburban forum but I don't have privileges to do so. I appreciate any feedback or pics of similar installs.
Thank you!
-BCCHowdy
Thank you!
-BCCHowdy
