Need some help with my TPI. After sitting for about 2 years it was hard to start and would backfire out the exhaust under acceleration and while just idling in gear. I pulled the injectors and ultrasonic cleaned them in seafoam while pulsing them, and that fixed the hard cold start, but it still backfires under acceleration. Put in a new O2 sensor and it does the same thing. It doesn't have any codes. Checked timing and it's at 0* at idle. I've had the TPI in and running for years, but it has sat due to an overheating issue that I fixed.
