TPI SBC FAST XFI XIM EFI Connections Cam and Crank sensors
Thanks AJ, going back into the workshop tomorrow for the final assembly and fix some leaks. Still have to finish brakes(rotors) from rock auto, unless someone has a better source.
Cam is broken in, so I don't have to worry about that any more. Power streering pulley has a bit of wobble, and alternater is humming
What's the latest? Loving it!
Since the engine runs, I am now working on the safety issues to get it inspected, light, w/s wipers, and emergency brakes. Had to raise handles up to clear floorboard at the clevis, so it would swing up w/o interference, now, I can brake to either back wheel
Also, had to add a spacer to the rear mount for clearance, but other than that, it was a direct fit from Lokar parts
Thanks for asking and following along
16399297168096328773701209060490 by https://www.flickr.com/photos/97391199@N06
