jp0863
Over the last few days I have experienced really high idle speeds. I jumped the aldl and got 22 (tps). When I started the truck it seemed to run at the right idle speed. Took the air cleaner off and wiggled the tps connector. As soon as I touched it, the idle went up to around 1200-1500 rpm (just a guess). I unplugged the tps connector and the engine kept running at the same speed. Shouldn't it have died? Or at least dropped rpm? Seems with no signal it should have done something different. Any thoughts? The tps sensor is new, the connector is new. Is it just a bad tps?
