A seperate question that needs an answer:
Which of the windstar fans should I use as my primary puller? I've read that they pull enough to only need one really...
Big fan:
=>Smaller/compact motor casing (lighter duty?)
=>Bigger fan would suck more juice??
=>My fan setup is off-center, so the larger fan has 1/3 of it not directly pulling air through the the rad.
Small Fan:
=>The motor can seems to be larger (maybe it's meant to be the primary puller out of the two fans...)
=>Smaller fan wouldn't use as much power... maybe...
=>Since my fans are off-center, the smaller fan has to cool 50% of the rad on it's own... Could the smaller fan even accomplish this task??
Also I am running two adjustable Fan switches. Hooking them up will be relatively simple... I just don't know where I can find two 3/8 NPT ports. Or even ports slightly larger that I could use a bushing on.
I have an 89' TBI engine, and I know it has a temp. sensor on it, but are there other unused ports? I see the two right near the base of the throttle body, but I thought those just go to the runner tubes...
And there is one on the passenger side cylinder head, but my header flange covers that baby right I think....
Are there any other places?? I need two ports... Unless I can splice, and run one temp. sensor. I don't see why not really.
