Mudmanmaniac
Registered Member
I use regular atf fluid in a 700r and do I use trhe same for the np241? Or is there something different for that?
that is also a good reason haha.The reason why you use the same fluid for both is because they can cross talk with eachother if the seals leak. You'll be fine with Dextron III in both.
