I had my son get in and shift. Yes, In neutral just going all the way towards the firewall and back.. i think he was a bit awe struck just sitting in there, so it may not be perfect shift but hopefully enough for better eyes to see whats going on
There are some knock off wheels that look nearly the same. They should say Weld on them somewhere if they are really made by Weld.They are 3 are the same but the driver side has it where it’s difficult to get to the lug nuts. Seem slightly different
I’ll have to double check, wasnt aware of that.There are some knock off wheels that look nearly the same. They should say Weld on them somewhere if they are really made by Weld.
The twin stick is nice, however I believe that you may have to decide if it's worth it. I have a triple stick in my '90 from ORD on a doubler from them. I like the positive shifting but mine needed some extra clearance made in the transmission tunnel even with the 1" body lift. A twin stick probably won't have that issue, but I have no experience with one. And mine aren't 100% rattle free, but I only have to have a rubber band around the 2 for the 205, so it's probably due to minor driveshaft harmonics getting into the 205.
I will tell you that back in the nineties, I took a 203 shifter apart and cleaned it completely then lubricated it with grease for my Dad's truck. It worked well after that, even after 20 years of getting the whole truck muddy during hunting. It wasn't a terrible job from what I remember, but I wouldn't be able to tell you how to do it without hands on it.
Your shifter looks pretty good compared to ones that I have taken out of trucks, but could there be an internal problem? You will have to determine that.
I personally don't believe that you are getting low range. I honestly wonder if there is a problem in the T-case shifter because it doesn't seem to push the range section towards the rear of the truck very far. I wonder if the reason that the shifter was so clean is because someone had it apart trying to fix it. It does look like you are getting the front output to lock and unlock.
With the engine off like that, you don't need be concerned about leaving in park, but you may need to twist the rear driveshaft back and forth to let things line up to get low range. Those are helical cut gears, but they may need a little movement to line up and change ranges.
I honestly think that you are only getting high range, high lock and possibly neutral . So until you want or need low range, I don't believe that you have a problem, just check that you don't have the front output locked in for street driving.
I would disconnect the shifter linkage from the outer lever of the transfer case, and see if you get more movement of that lever than the shifter is able to do.
OK, first of all, let me clear up one misunderstanding.
Forget the "whine" you read about the low range.
The whine they were talking about is not the transmission or transfer case, its the engine. In low range, the system is geared so low, that your engine will sound like its about to blow over about 25 or 30. I have a 205 in my truck, and once wound it out in low range. I don't remember which has the lower gear, but they are close. My engine redlined at 40. In other words, that was as fast as the truck could go, and I was risking engine damage going that fast.
If you can cruise at 40 and above, you are NOT in low range, no matter where the lever is pointing
