Wanted Transfer case brace
Discussion in 'Parts & Trucks Wanted' started by mblove48, Apr 13, 2019.
  1. mblove48
    mblove48 Registered Member Premium Member
    Apr 11, 2019
    7
    Ellijay, Ga
    For a 1987 6.2 diesel, 700R4, 205 cast iron transfer case. New torque converter, rebuilt transmission and transfer case because the puny4 bolts did not support the transfer case very well. Actually, it broke loose. Would like to have a little more support for the TC.
    rhinoblzr likes this.
  2. Jimbo*
    Jimbo* 1/2 ton status Premium Member
    Mar 8, 2005
    1,449
    8
    roswell, new mexico
    Are you looking for the rod that attaches to the side of the 208, and runs up to the bellhousing?
  3. mblove48
    Apr 11, 2019
    7
    Ellijay, Ga
  4. Jimbo*
    Mar 8, 2005
    1,449
    8
    roswell, new mexico
    I think I still have one attached, will know later this week.
  5. mblove48
    Apr 11, 2019
    7
    Ellijay, Ga
    Great. Two of my transfer case bolts are just heli coiled and I need some support for that cast iron monster
  6. Jimbo*
    Mar 8, 2005
    1,449
    8
    roswell, new mexico
    Uhhh, the 208 is not cast iron, but aluminum.
  7. campfire
    campfire Adventure is out there! Premium Member
    Jun 7, 2013
    23,411
    12,284
    Northwoods Wisconsin / da U.P.
    Build(s):
    3
    This. Assuming you have the aluminum 208, it should have a single brace running up to the bell housing.
    If Jimbo can't find his, I have one that's in two pieces. Or you could just measure the distance and make your own.
  8. mblove48
    Apr 11, 2019
    7
    Ellijay, Ga
    Well, it's definately cast iron, and the specs on the 6.2 Diesel said it was a 208.
    Spec sheet could be wrong. What is the cast iron one?
  9. Jimbo*
    Mar 8, 2005
    1,449
    8
    roswell, new mexico
    Well, with a little luck, you have an NP205, gear drive T/C. If so, this is good!
    On the other hand, it could be an NP203, chain drive T/C, and this would not necessarily be bad, but very heavy.
    There should be a round aluminum tag on the back of the T/C that will identify it.
  10. sweetk30
    sweetk30 selective wrench turner guy Premium Member
    Nov 1, 2004
    31,409
    6,389
    horseheads , ny 14845
    Build(s):
    4
    No tags on dear of 203 & 205 there on front side and rectangle shape .
  11. mblove48
    Apr 11, 2019
    7
    Ellijay, Ga
    Mechanic showed me what he rebuilt, and it was definitely geared. Its heavy.
    So that means it's a 205, right? I'll look and make sure, though.
  12. sweetk30
    Nov 1, 2004
    31,409
    6,389
    Build(s):
    4
    205 part time 4x4 gear to gear fixed yoke rear output. note the little 3 bolt cover between the 2 big ones .
    203 full time 4x4 chain drive case . note the huge aluminum tail section .
  13. Jimbo*
    Mar 8, 2005
    1,449
    8
    roswell, new mexico
    No luck, my 700R4/NP208 is without side brace, but it probably would be the wrong length anyway. Grab the one listed above, and weld a sleeve to the proper length.
