will a 1974 np203 with TH350 bolt right into my 1978 blazer?
Yes... a guy locally has an np203 with part time kit (just like mine) for like $100.he is switching to np205.If they are both from a TH350, yes.
Edit - I'm guessing you have an np203 in the '78, right?
Good idea. Im about tapped for cash hopefully the ORD kit isnt too expensiveGotcha, yes it should be a direct swap.
Note that np203 shifters are problematic so if you use this truck in 4wd much this might be a good time to consider a shifter upgrade. Off Road Design make a twin stick conversion for the np203.
Thanks. Im going to order it.
In my 30s I wrestled 203s in by myself with no Jack. In my 50s now and last time I worked on one I used the transmission jack.Is this install possible and safe to do alone? I’m looking into a tranny jack or that adapter thing you can use on a floor jack. I know the np203 is heeeeeaaavy like 300lbs.
If you have a good adjustable adapter it should go smooth
I had to get help to put my 203 back on the jack to install in the truck. I didn’t have a low profile jack then either and barely cleared the frame rail when removing from under the truck with 35’s.
Does seem awfully high. I may keep browsingThe 203 is definitely off balance. Caution.
75$ for TC mounts better be good.
I'd chain or ratchet strap the t-case to the jack adapter ,then you wont have to have an EMT remove it from your skull if it decides to slip--and they do,because its not well balanced and the shape of it makes it tough to sit on the adapter squarely..
I have R &R'd several t-cases alone,but didn't enjoy doing it--no one to call for help sucks if something goes sour,the other person doesn't need to help install it or know how to do anything but dial a phone..
For what you want to do it is safer with a transmission Jack but that one you show could be good enough if you secure it well to the Jack.Would you suggest the transmission jack to be somewhere safer? I see they have one that lays flat and can rise. The others Ive seen, appear to be for those fortunate enough to have a vehicle lift.
It’s going to be a real hoot trying to get the one Im picking up today, out of my car... hahahahaha
Anyone in Gilbert, AZ hahahahahahah
This one looks decent
https://www.amazon.com/Performance-...=2025&creative=165953&creativeASIN=B000N322K0
