I think I have enough room, 4” lift and 37’s. I have a lo profile jack. Plus another jack if needed... shi$ looks sketchy to do. Not really looking forward to doing this.
I was looking at those, similar to a motorcycle jack?I use an ATV jack just because I bought one when no body in the area had a transmission jack when I needed one. They are cheap and work well. Also once you get it lowered down under the truck, you can always jack the truck up for extra clearance. I often let the air out of the tires to work on it and get it ready then air back up and jack it up more if needed. But then I have 37's and 8 inches or so of lift. Safety is key, ratchet straps if nothing else help.
Shi&....I wish..get all 3 and then give us a comparison test![]()
First, the spacer in between the brackets is a must, if your old one didn't have it it explains why they were wobbly.My present one is the green one, I noctice where the front drive shaft engages the mounting bracket is different than the one I just picked up.
The one on my truck right now has no spacer. I cleaned up the one I picked up and saw the nut on the yoke.First, the spacer in between the brackets is a must, if your old one didn't have it it explains why they were wobbly.
The yoke on the driveshafts can be swapped if you don't want to change driveshafts.
I prefer the flanges over the yokes but match what you have on the truck
