Leper
loafer said:Bolt grip is the length of bolt between the nut and bolt head. If the grip length is too short it cannot be properly preloaded and will have a tendency to loosen; Think of the bolt as a spring with a high stiffness. The spacers basically insure that the spring is long enough for the given diameter. As a general rule of thumb, the grip length should be at least 2.5x the bolt diameter. Make any sence?![]()
It's not going to change anything if you move the spacer to the other side, as long as it is still there.
