How in the hell can you call a 205 a "sh!tty" transfercase? Are you just angry and reaching for something or what?
I get that you don't prefer them, that's fine, spice of life/everyone is different and all that...but calling a NP205 a sh!tty transfercase is just ignorant.The only disadvantage it has is gearing.
Did ya watch the video?...think you could make a 205 explode like that 208? ...on dirt, stock 1/2 ton running gear, stock tires, probably stock gearing? You can't, even if the mount was trashed, I know, I absolutely blew apart a stock 205 mount, adapter never even snorted, skidding a 40" diameter 10' long fresh cut cedar log up a hill. Everything under the truck was banging around...the entire drivetrain. I had to weld the mount together, AFTER skidding the log, just to get home. Replaced the mount, went back to skidding logs.
Soon as the 8.1 is in, the chassis/suspension is setup appropriately and everything is ready to rip...I know a place where I can chain my truck to a huge bridge overpass. I'm going to hook up, do some 8klb 6 wheel peel's, with a good bit of weight in the back, and get down on a reasonable effort to break something. I have $100 that says the 205 doesn't even snort. I'm guessing I explode a Warn 35 spline hub first. I wish it was a simple thing for me to swap an aluminoob case into my truck, just to explode it and prove a point.
I encourage anyone who wants to make the drive, has an aluminoob case and has the balls to chain up to an immovable object, or do tug o war with me, to do so. Let's see if the faith in aluminum cases is miss-placed or not.
"Ratings", or things from books are dumb things to quote in support of an argument like this. Real world experience trumps all.![]()
One thing I like better about the 205 over the 241 is the ability to twin-stick. Sorely wish I could twin stick the 241.
I'm beginning to wonder if Marty should have clarified this voting thread as "which t-case for this type of driving....." as I can see a lot of answers here are generating from guys who are using 208's or 241's under their current rigs or daily drivers. I'd bet if they had the time and money they would quickly upgrade to the 205 and call it done.
Now if Marty's voting title were something along the lines of "which t-case do you prefer for hardcore off roading" or "which t-case do you prefer for using as a highway queen", etc.
Anyway, Martin, did you have a particular use in mind?
It's another one of those "depends on the application" things. I would most like to have it for the snow runs we do. Having a front locker can make it hard to turn in snow.I felt that way once. Before I had a twin sticked NP205. It sounds great on paper, but I have found it to be completely worthless in real world experience.
Martin
A lot of trails we run are steep and necessitate using 4Lo but also have switchbacks that require 2 or 3 point turns even in a K5. Those are times I wish I had twin stick too.
I have two 205 cases in my parts stash so obviously it's no a high priority or I'd have done the swap.
How do you get the front digs to do anything? Hold the brakes?
Martin
