Transfer case vent tube leak
zombiyjay76
Santa Fe
I found a pretty good leak on the vent tube housing. The small metal tube that comes out of the case is loose.
Do I need to remove the transfer case to tighten this up, or is there a way to do this while its still in the truck?
It looks like the tube is just pressed in there. (Any upgrade part out there to replace the tube?) Tried searching but could not find anything.
This is on a 90 blazer, with a 241 transfer case.
