NH Transfer Cases, Transmissions, Adapters
GonicGM
Seacoast New Hampshire
32 Spline NP 205 Transfer case, passenger drop. Can mate to either TH400 or 1981 or newer 32 spline SM465 4 speed, $350 (local only)
32 Spline NP 208 Transfer case, passenger drop. Can mate to either TH400 or 1981 or newer 32 spline SM465 4 speed, $250 (local only)
32 Spline SM465 4x4 4 speed tranny, has long 32 spline tailshaft. $250 Compatable with 1981 or newer TH400 NP208/NP241 and 1985 or newer TH400 NP205, for those of you who want to convert from TH400 to 4 speed standard. (local only)
SM465 tall transfer case adapter to NP208 $125 required to swap SM465 onto TH400 NP208 for conversion.(requires 1984 and older crossmember).
SM465 short transfer case adapter to NP208 $100 required to swap SM465 onto TH400 NP208 for conversion.(requires 1985 and newer crossmember). SOLD
SM465 short transfer case adapter to NP205 $150 required to swap 32 spline SM465 onto TH400 NP205 round pattern, for conversion.
TH400 to NP205 short adapter. $225 Excellent condition, great for SM465 4 speed to TH400 swap, required to install TH400 onto NP205 from 1985-1991.
TH400 to NP205 tall adapter. $200 Excellent condition, fits 77-84.
TH400 to NP208 tall adapter. $175 Excellent condition, great for SM465 4 speed to TH400 swap, required to install TH400 onto NP208 from 1981-1991 (requires 1984 and older crossmember).
TH400 to NP208 short adapter. $100 Excellent condition, great for SM465 4 speed to TH400 swap, required to install TH400 onto NP208 from 1981-1991 (requires 1985-1991 crossmember).
1985-1991 Double hump crossmember. This crossmember is required on 85-91 solid axle trucks and to retrofit short style adapter installs to 84 and older, may not compatable with 87-up OEM catalytic converter. $85
1985-1991 Single hump crossmember. This crossmember is required on 85-91 solid axle trucks and to retrofit short style adapter installs to 84 and older, may be required with 87-up OEM catalytic converter. $65
1985-1991 Skid plate for single hump crossmember $45
Can arrange free delivery off rts. 95 128 93 495 395 from Wells Me. to New London Ct. (NH Mass. Me. Ct. RI)
Do you still have the th400 to 205 short adaptor?
also need th400 to 208 short adaptor, plus the w hump cross mwmber
thanks
How much to ship the NP 205 to 73089? Thanks
Probably has to go truck freight. Cheapest will be to a business in business zone with a loading dock and normal business hours. Do you have that available? Do you need adapter? If yes, TH400 or SM465?
Thanks, PM sent.
Kind of a long shot....but do you have either a 32spline round pattern 205 or 32spline 208/241? Looking for one to go behind a Nv4500.
Yes, 32 spline round pattern 205 still available as advertised.
Well, I'm interested in that one. Can I get a shipping quote to 48611 (my zip code). Or, I have a Fastenal near by that I've used to big/heavy items before. MIMID is their number I believe.1708 Bay City Road. Midland, MI USA 48640 is their address.
Will do Monday, local Fastenal very accomodating.
whats the difference between the short 465 t case to 208 adaptor vs the short 465 to 205 tcase adaptor? I thought that they were the same.
205 adaptors have a boss for the shifter bolt hole provision.
