GonicGM
32 Spline NP 205 Transfer case, passenger drop. Can mate to either TH400 or 1981 or newer 32 spline SM465 4 speed, $350 (local only)
32 Spline NP 208 Transfer case, passenger drop. Can mate to either TH400 or 1981 or newer 32 spline SM465 4 speed, $250 (local only)
32 Spline SM465 4x4 4 speed tranny, has long 32 spline tailshaft. $250 Compatable with 1981 or newer TH400 NP208/NP241 and 1985 or newer TH400 NP205, for those of you who want to convert from TH400 to 4 speed standard. (local only)
SM465 tall transfer case adapter to NP208 $125 required to swap SM465 onto TH400 NP208 for conversion.(requires 1984 and older crossmember).
SM465 short transfer case adapter to NP208 $100 required to swap SM465 onto TH400 NP208 for conversion.(requires 1985 and newer crossmember). SOLD
SM465 short transfer case adapter to NP205 $150 required to swap 32 spline SM465 onto TH400 NP205 round pattern, for conversion.
TH400 to NP205 short adapter. $225 Excellent condition, great for SM465 4 speed to TH400 swap, required to install TH400 onto NP205 from 1985-1991.
TH400 to NP205 tall adapter. $200 Excellent condition, fits 77-84.
TH400 to NP208 tall adapter. $175 Excellent condition, great for SM465 4 speed to TH400 swap, required to install TH400 onto NP208 from 1981-1991 (requires 1984 and older crossmember).
TH400 to NP208 short adapter. $100 Excellent condition, great for SM465 4 speed to TH400 swap, required to install TH400 onto NP208 from 1981-1991 (requires 1985-1991 crossmember).
1985-1991 Double hump crossmember. This crossmember is required on 85-91 solid axle trucks and to retrofit short style adapter installs to 84 and older, may not compatable with 87-up OEM catalytic converter. $85
1985-1991 Single hump crossmember. This crossmember is required on 85-91 solid axle trucks and to retrofit short style adapter installs to 84 and older, may be required with 87-up OEM catalytic converter. $65
1985-1991 Skid plate for single hump crossmember $45
Can arrange free delivery off rts. 95 128 93 495 395 from Wells Me. to New London Ct. (NH Mass. Me. Ct. RI)
